Need help HAproxy in bridge mode between 2 ssl connection for CAS server
Hi Guys,
I am trying to configure cas servers to use a haproxy+keepalive with the main cert for the site on haproxy and wildcard certs for the CAS servers in the pool.
I can get to the CAS Servers but if i got to tomcat management portal it shows as the client ip the one of the haproxy instead of the client i am accessing it from.
the configuration i am having so far is the following:
    # Example configuration for a possible web application.  See the
    # full configuration options online.
    #   http://haproxy.1wt.eu/download/1.4/doc/configuration.txt
    # Global settings
        # need to:
        # 1) configure syslog to accept network log events.  This is done
        #    by adding the '-r' option to the SYSLOGD_OPTIONS in
        #    /etc/sysconfig/syslog
        #   file. A line like the following can be added to
        #    local2.*                       /var/log/haproxy.log
        log         127.0.0.1 local2 debug
        ##TT ADDING LOGGING TO RSYSLOG ON 127.0.0.1
        chroot      /var/lib/haproxy
        maxconn     4000
        user        haproxy
        group       haproxy
        # turn on stats unix socket
        mode                    http
        retries                 3
        timeout http-request    10s
        timeout queue           1m
        timeout connect         10s
        timeout client          1m
        timeout server          1m
        timeout http-keep-alive 10s
        timeout check           10s
        maxconn                 3000
    #TT
        stats                   enable
        stats                   uri /stats
        stats auth******:*********
    frontend  main
        bind 10.1.1.112:8443,10.2.1.3:8443 ssl crt /etc/pki/tls/private/casdev.test.lab-conmbined-key-and-cert.pem
    #     bind *:8443 ssl crt /etc/pki/tls/private/casdev.test.lab-conmbined-key-and-cert.pem
    #    http-request add-header X-Client-IP %[src]
    #    http-request add-header X-Forwarded-Port %[dst_port]
    #    http-request add-header X-Forwarded-For %[src]
    #    http-request add-header X-Forwarded-Proto https if { ssl_fc }
        reqadd X-forwarded-Port:\ 8443
        acl url_static       path_beg       -i /static /images /javascript /stylesheets
        acl url_static       path_end       -i .jpg .gif .png .css .js
    #    use_backend static          if url_static
        default_backend             app
    ##TT
    frontend web1
        bind 10.2.1.3:80,10.1.1.112:80
    #    bind 10.2.1.3:80,10.1.1.112:80
    default_backend             web1
    # static backend for serving up images, stylesheets and such
    backend static
        balance     roundrobin
        server      static 127.0.0.1:4331 check
    # round robin balancing between the various backends
    #backend app
    #    balance     roundrobin
    #    server  app1 127.0.0.1:5001 check
    #    server  app2 127.0.0.1:5002 check
    #    server  app3 127.0.0.1:5003 check
    #    server  app4 127.0.0.1:5004 check
    ##TT
    backend app
        balance     roundrobin
        #option httpchk GET /health_check
        option  redispatch
        server cas1.test.lab 10.1.1.101:8443  check ssl cookie required ca-file /etc/pki/tls/certs/ca-chain.cert.pem
        server cas2.test.lab 10.1.1.102:8443  check ssl cookie required ca-file /etc/pki/tls/certs/ca-chain.cert.pem
    backend web1
        balance     roundrobin
    server web1.test.lab 10.1.1.120:80 check
    server web2.test.lab 10.1.1.121:80 check
