Need help on why https doesn't work
Hi I don’t know why https doesn’t work. Http works perfectly.
Here is my haproxy.cfg. And my haproxy is version “HA-Proxy version 1.6.3 2015/12/25”
xxx.xxx.xxx is my target backend server. I don’t know what’s wrong with my haproxy.cfg. And i const
log 127.0.0.1:514 local0
resolvers dns
nameserver hk 210.177.255.186:53
hold valid 1s
frontend http_api
acl network_allowed src 10.28.0.0/14 10.32.0.0/14 10.12.0.0/14 10.60.0.0/14
acl google hdr_beg(host) -i www.google.com
http-request deny if !network_allowed
use_backend google_backend if google
frontend https_api
bind *:443
acl misumi hdr_beg(host) -i xxx.xxx.xxx
use_backend misumi_backend if misumi
server google www.google.com:80 check inter 1000 resolvers dns
#server nginx 10.128.0.121:80
server misumi xxx.xxx.xxx:443 check inter 1000 resolvers dns
frontend https_api
 bind *:443
The configuration is wrong. You are trying to access the host header in the HTTP request (acl misumi), which is not available because a) you are in TCP mode and b) the SSL traffic is encrypted, so you’d never be able to access that host header.
Suggestions:
  • use default_backend misumi_backend without an ACL
  • decrypt SSL by installing the certificate on haproxy
  • access SNI instead, see below
SNI config:
acl misumi req_ssl_sni -i www.example.org
using 443 port is not a must. I can use port 8080. So i want to have request (https) -> haproxy -> backend server. I only need haproxy to send request to backend with https. It’s not a must to use https to call haproxy, so i don’t think i need to install ssl certificate and use ssl to decrypt request.
And to be more precise, I’m using the curl command to test and it returns me with below error.
curl https:// --proxy http://:8080
error
curl: (56) Received HTTP code 400 from proxy after CONNECT
i followed your suggestions and below is my configuration.
resolvers dns
hold valid 1s
frontend http_api
frontend misumi_https
bind *:8080
acl misumi req_ssl_sni -i xxx.xxx.xxx
server misumi dsd.misumi.sh.cn:443 check inter 1000 resolvers dns
bind :8989
stats refresh 30s
stats uri /stats
stats auth abc:abc
Which exact port you use does not matter.
Right, then use default_backend as suggested, not an ACL with a condition based on a HTTP header.
This is wrong. Haproxy is not a forward proxy, it’s a reverse proxy. The call needs to be (if on port 443):
curl https://<haproxyIP/
hmm i think you misunderstand this
curl https://<haproxyIP>/
my command is
curl https:// <backend server> --proxy http://<haproxy ip>
. In this scenario i still need to use https for my haproxy ? i thought it’s not a must.
No, reread what I just said.
You don’t use the --proxy argument with curl.
