Need to remove 1st part of URL
I have to redirect my URL to the following address and then remove the 1st part of the URL and then send it to the backend.
The absolute URL is: https://test.domain.com
It should redirect to the: https://test.domain.com/portal
then I should remove the first part (Portal I mean) and then add the next parts (after /portal) to the URL and send it to the backend.
**the final URL which must send to the backend should be something like this: https://test.domain.com/dist/… **
The HAProxy version is: HA-Proxy version 1.8.4-1deb90d 2018/02/08
Now I have the following configuration:
frontend MAIN-HTTPS
bind :443 ssl transparent crt /etc/ssl/certs
acl test hdr(host) test.domain.com
reqirep ^([^\ :]
)\ /(.*) \1\ /portal/\2 if test
use_backend testPortal if test
backend testPortal
acl no_redir url_beg /portal
reqrep ^([^\ :])\ /(.) \1\ /portal/\2 if no_redir
http-request redirect scheme https if !{ ssl_fc }
server web-testPortal test.domain.com:100 check
please help me!
I would suggest using regsub fetch transform in the backend, something similar to:
http-request set-path "%[path,regsub(^/portal/,/)]"
Thanks Ciprian
I used regsub exactly as you mentioned but the /portal part is still there!
my backend configuration is as below
backend testPortal
http-request set-path “%[path,regsub(^/portal/,/)]”
do you have any recommendation?
:pray:
What URL’s are you trying?
For example:
  • /portal/whatever -> /whatever – should work;
  • /portal/ -> / – should also work;
  • /portal – shouldn’t work as it’s missing the last /;
You should adapt the regular expression as needed, like for example: ^/portal(/|$). (Please note that the HAProxy syntax does impose some limitations, therefore you need to experiment a little…)
Dear Ciprian,
Thank you very much. I was wrong and your solution worked like a charm.
:handshake::clap::heart_eyes:
