I have a virtualbox lab with two servers with IIS installed and a test website i found called guitarbugs, which is internally accessible, and which is setup in IIS on both servers with working bindings for http.
As well as adding the site in DNS (on the DC), also with A records for both the servers which point to the guitarbugs site.
I can access the site fine on a windows 10 machine on the same LAN.
I have setup HAproxy for http for the time being to see how it works, but for some reason when i access the stats page i get no information on sessions when i access the page from the win 10 machine.
It’s almost as if it is not seeing the site.
If i turn off one of the servers the stats page registers that the server is down, but it is almost as if it doesn’t register actual sessions.
I’m not sure if there is some sort of special setup i have to do in IIS?. I just copied the sites folder to each server.
This is my config as well. I really do appreciate your help and assistance, as I’m stumped. Thanks again!
frontend localnodes
default_backend web_servers
backend web_servers
server dc-1 192.168.100.2:80 check
server sql-1 192.168.100.3:80 check
bind *:32700
stats uri /
stats auth paul:123456
stats admin if TRUE
