I’ve been running NextCloud, non-AIO on unraid (network: br0 ipvlan, with its own local host ip, 192.168.2.xx) for years without problem and without OnlyOffice integration. HAProxy on my pfSense as a reverse proxy.
During the past week, I tried Opencloud, with OnlyOffice integration, and it works beautifully. OpenCloud, Wopi, and OnlyOffice are under the same Docker network on Unraid.
Later, I installed the OnlyOffice connector from Nextcloud Apps, set the OnlyOffice JWT secret key and onlyoffice public domain. However, when I tried to save the setting, there was an error:
Error when trying to connect (Error occurred in the document service: Invalid token)
The JWT secret is definitely correct. I don’t know why it doesn’t work.
FYI, all services are reverse-proxied by HAProxy on pfSense.
Another information, I also run OpenCloud and OnlyOffice docker containers on Oracle VPS with the other public domain. They are also working fine. If I set my unraid Nextcloud to integrate with my Oracle VPS OnlyOffice, it just works!.
Could it be somehow due to some additional settings I need to do on HAProxy?
