I’m running Nextcloud behind HAproxy 1.5 on a CentOS 7 virtual machine. All seems to work fine except when I try to download some large files. The download starts but randomly the downstream drops to 0Kbps. Some times it drops when it has downloaded 1MB and someother times drops when the download is more than 100MB. I couldn’t find any correlation about when the download drops nor anything in logfiles.
Sometimes the downloads works as expected, I succesfully downloaded files bigger than 2GB. It makes a mess and I don’t know where to look for.
any suggestion?
I post some details about the server:
haproxy.conf
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 4000
tune.ssl.cachesize 1000000
ssl-default-bind-ciphers EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH
timeout http-request 30s
timeout queue 1m
timeout connect 30s
timeout client 5000
timeout server 30s
timeout http-keep-alive 30s
timeout check 30s
maxconn 30000
frontend http
bind 0.0.0.0:80
#ACLs
acl host_cloud_cmp hdr_beg(host) -i cloud.company.com
use_backend cloud_cmp if host_cloud_cmp
frontend https
http-response set-header Strict-Transport-Security max-age=31536000;\ includeSubdomains;\ preload
http-response set-header X-Frame-Options DENY
bind 0.0.0.0:443 ssl crt /etc/haproxy/wildcard.company.com.pem
#ACLs
use_backend cloud_cmp-https if host_cloud_cmp
backend cloud_cmp
option http-pretend-keepalive
option forwardfor header X-Real-IP
cookie NEXTCLOUD insert indirect nocache
stick-table type ip size 200k expire 30m
stick on src
http-response set-header Strict-Transport-Security max-age=16000000;\ includeSubDomains;\ preload;
server NEXTCLOUDSERVER NEXTCLOUDSERVER:80 check cookie NEXTCLOUDSERVER
haproxy -v
Copyright 2000-2016 Willy Tarreau
uname -ir
3.10.0-514.16.1.el7.x86_64 x86_64
4CPU, 4GB of RAM
Low CPU Usage
09:20:01 PM CPU %user %nice %system %iowait %steal %idle
09:30:01 PM all 0.21 0.01 0.05 0.00 0.00 99.73
09:40:01 PM all 0.21 0.01 0.05 0.00 0.00 99.72
09:50:02 PM all 0.22 0.01 0.06 0.00 0.00 99.72
10:00:01 PM all 0.21 0.01 0.05 0.00 0.00 99.72
10:10:01 PM all 0.21 0.01 0.06 0.00 0.00 99.72
10:20:01 PM all 0.21 0.01 0.06 0.00 0.00 99.72
10:30:01 PM all 0.21 0.01 0.06 0.00 0.00 99.73
10:40:01 PM all 0.21 0.01 0.06 0.00 0.00 99.72
10:50:01 PM all 0.21 0.01 0.06 0.00 0.00 99.72
11:00:01 PM all 0.21 0.01 0.06 0.00 0.00 99.73
11:10:01 PM all 0.22 0.01 0.06 0.00 0.00 99.72
11:20:01 PM all 0.21 0.01 0.06 0.00 0.00 99.72
11:30:01 PM all 0.21 0.01 0.06 0.00 0.00 99.72
11:40:01 PM all 0.22 0.01 0.06 0.00 0.00 99.72
11:50:01 PM all 0.21 0.01 0.05 0.00 0.00 99.73
