Hello.
I’m following Introduction to HAProxy Logging and I’m configuring my HAProxy 2.4.22 as follows:
haproxy.cfg:
log 127.0.0.1:514 local2
chroot /var/empty
pidfile /run/ldap-proxy.pid
maxconn 4096
user ldapp
group ldapp
ssl-default-server-ciphers PROFILE=SYSTEM
timeout client 30s
timeout server 30s
listen ldap
bind :389
option ldap-check
option log-separate-errors
server ldaps foo:636 ssl ca-file /etc/pki/tls/cert.pem check
frontend stats
bind :8080
stats uri /stats
stats refresh 30s
stats show-node
stats admin if LOCALHOST
and /etc/rsyslog.d/ldap-proxy.conf as:
# Collect log with UDP
$ModLoad imudp
$UDPServerAddress 127.0.0.1
$UDPServerRun 514
# Set the default permissions for all log files
$DirOwner ldapp
$DirGroup ldapp
$FileOwner ldapp
$FileGroup ldapp
$FileCreateMode 0640
$DirCreateMode 0754
$Umask 0027
# Creating separate log files based on the severity
local2.* /var/log/ldap-proxy/traffic.log
local2.notice /var/log/ldap-proxy/admin.log
but the only log file that I get created is traffic.log.
Even if I restart the services, the admin.log doesn’t get created.
What am I doing wrong?
Kind regards and thanks for the support.
