On-marked-up shutdown-backup-sessions with backups?
I have multiple backends for a service that should have all traffic going to a single server. I want connections to be killed when the active server goes down (handles itself), but HAProxy to kill the connections when it comes back up.
It sounds like ‘no-marked-up shutdown-backup-sessions’ is what I’m after, but this doesn’t seem to work when you have multiple backup servers.
Our standard config has all the servers marked as backup, and allbackups disabled. This correctly causes all traffic to go to the first server in the list (what we want).
If we shutdown that server (redis1 in the example), traffic goes to the second server in the list (redis2).
However, if the first server comes back online (docker-compose start redis1), connections do not get killed.
The setup works if redis1 is not marked as a backup, but then it doesn’t work when redis2 fails over to redis3.
Example config:
  stats socket /var/run/api.sock user haproxy group haproxy mode 660 level admin expose-fd listeners
  log stdout format raw local0 info
  timeout client 10s
  timeout server 10s
  timeout http-request 10s
frontend stats
  bind *:1337
  stats uri /
  stats refresh 10s
listen redis
  bind *:6379
  maxconn 20000
  no log
  no option allbackups
  option tcp-check
  option dontlog-normal
  option tcpka
  option clitcpka
  tcp-check send "PING\r\n"
  tcp-check expect string "+PONG"
  tcp-check send "QUIT\r\n"
  tcp-check expect string "+OK"
  timeout connect 4s
  timeout server 330s
  timeout client 330s
  server redis1 redis1:6379 backup check on-marked-up shutdown-backup-sessions on-marked-down shutdown-sessions
  server redis2 redis2:6379 backup check on-marked-up shutdown-backup-sessions on-marked-down shutdown-sessions
  server redis3 redis3:6379 backup check on-marked-up shutdown-backup-sessions on-marked-down shutdown-sessions
docker-compose setup
services:
  redis1:
    image: eqalpha/keydb:x86_64_v6.3.1
  redis2:
  redis3:
  haproxy:
    image: haproxytech/haproxy-alpine:2.6
    ports:
      - 6379:6379
      - 1337:1337
    volumes:
      - .:/usr/local/etc/haproxy:ro
Demo:
docker-compose up -d
redis-cli monitor (this will show pings fine)
docker-compose stop redis1
# redis-cli disconnects (as expected)
redis-cli monitor (start it up again, it'll be pinging)
Expected behaviour is that redis-cli disconnects.
Actual behaviour is redis-cli stays connected to the redis2, ignoring the ‘on-marked-up shutdown-backup-sessions’.
