Hello
I’m looking to use Haproxy backup on a series of RabbitMQ clusters, I have it working, all except for when the primary cluster returns… On failback the connections still on the backup cluster persist (causing a split brain).
Is there away to force connections to close (on the backup) if there is a failback (to primary)?
Or even if there is a way to stop a failback (auto back to primary on recovery) occur unless the service is restarted?
I’ve been through lots of docs, but all I can find it stuff saying, ‘yes it will persist’. If I can’t get this functionality the solution is a no go.
Thank you
ok I just tried,
non-stick
tested and didn’t work
You’ll need to share the output of haproxy -vv and the entire configuration.
What you are looking for is probably on-marked-up for the backup server.
see below, if you need anything else just let me know
Copyright 2000-2016 Willy Tarreau <willy@haproxy.org>
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -DTCP_USER_TIMEOUT=18
OPTIONS = USE_LINUX_TPROXY=1 USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_PCRE=1
maxconn 25000
timeout client 120s
timeout server 120s
bind 10.9.52.16:1978
stats realm Haproxy\ Statistics\ RabbitMQ
stats uri /
stats refresh 5s
# RabbitMQ
listen rabbit
bind 10.9.52.16:5672 v4v6
option tcp-check
option allbackups
server rabbit-0 10.9.52.31:5672 check inter 2000 rise 2 fall 3 maxconn 5000
server rabbit-1 10.9.52.32:5672 check inter 2000 rise 2 fall 3 maxconn 5000
server rabbit-2 10.9.52.33:5672 check inter 2000 rise 2 fall 3 maxconn 5000
server rabbit-3 137.237.136.228:5672 backup check inter 2000 rise 2 fall 3 maxconn 5000 non-stick
server rabbit-4 137.237.136.229:5672 backup check inter 2000 rise 2 fall 3 maxconn 5000 non-stick
server rabbit-5 137.237.138.23:5672 backup check inter 2000 rise 2 fall 3 maxconn 5000 non-stick
on-marked-up shutdown-backup-sessions on the primary servers should work just fine in this case.
I just tested it out, and it worked! THANK YOU @lukastribus
Here is my new config:
maxconn 25000
timeout client 120s
timeout server 120s
stats uri /
stats refresh 5s
# RabbitMQ
listen rabbit
option tcp-check
option allbackups
server rabbit-0 10.9.52.31:5672 check inter 2000 rise 2 fall 3 maxconn 5000 on-marked-up shutdown-backup-sessions
server rabbit-1 10.9.52.32:5672 check inter 2000 rise 2 fall 3 maxconn 5000 on-marked-up shutdown-backup-sessions
server rabbit-2 10.9.52.33:5672 check inter 2000 rise 2 fall 3 maxconn 5000 on-marked-up shutdown-backup-sessions
