Option forwardfor ignored for backend
Hi, haproxy status gives me these errors even though it seems to work:
$ systemctl status haproxy
Loaded: loaded (/usr/lib/systemd/system/haproxy.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2020-05-08 09:00:34 UTC; 22min ago
Process: 26543 ExecStartPre=/usr/sbin/haproxy -f $CONFIG -c -q (code=exited, status=0/SUCCESS)
Main PID: 26544 (haproxy)
Tasks: 2 (limit: 24956)
Memory: 14.9M
├─26544 /usr/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid
└─26546 /usr/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid
May 08 09:00:34 server1 haproxy[26544]: [WARNING] 128/090034 (26544) : config : ‘option forwardfor’ ignored for backend ‘port.5060’ as it requires HTTP mode.
May 08 09:00:34 server1 haproxy[26544]: [WARNING] 128/090034 (26544) : config : ‘option forwardfor’ ignored for backend ‘port.5061’ as it requires HTTP mode.
May 08 09:00:34 server1 systemd[1]: Started HAProxy Load Balancer.
My config file:
Global settings
# need to:
# /etc/sysconfig/syslog
log 127.0.0.1:514 local0
chroot      /var/lib/haproxy
maxconn     4000
user        haproxy
group       haproxy
# turn on stats unix socket
ssl-default-server-ciphers PROFILE=SYSTEM
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 2048
frontend main
bind *:5000
acl url_static path_beg -i /static /images /javascript /stylesheets
acl url_static path_end -i .jpg .gif .png .css .js
use_backend static          if url_static
default_backend             app
frontend stats
bind *:8404
stats uri /stats
stats refresh 10s
stats auth user:password
static backend for serving up images, stylesheets and such
backend static
server static 127.0.0.1:4331 check
round robin balancing between the various backends
backend app
server app1 127.0.0.1:5001 check
server app2 127.0.0.1:5002 check
server app3 127.0.0.1:5003 check
server app4 127.0.0.1:5004 check
My config
frontend port.5060
bind 172.16.10.100:5060
default_backend port.5060
frontend port.5061
bind 172.16.10.100:5061
default_backend port.5061
frontend website1:80
bind 172.16.10.99:80
default_backend website1:443
frontend website1:443
bind 172.16.10.99:443 ssl crt /etc/pki/tls/certificate.pem
backend port.5060
server gw1 192.168.100.121:5060 check
server gw2 192.168.100.122:5060 check
backend port.5061
server gw1 192.168.100.121:5061 check
server gw2 192.168.100.122:5061 check
backend website1:80
server web1 192.168.100.41:80 check verify none
server web2 192.168.100.42:80 check verify none
cookie SESSIONID insert indirect nocache
server web1 192.168.100.41:443 ssl check verify none cookie web1
server web2 192.168.100.42:443 ssl check verify none cookie web2
How can i solve it?
Thank in advanced!!
You cannot use HTTP options when you are in TCP mode.
Thanks for your help!
What would be the wrong http options?
Thanks!
Reading or modifying HTTP headers requires haproxy to actually parse the HTTP message, which is why http mode is required.
TCP mode means that the entire TCP payload is forwarded from one socket to the other (between frontend and backend, without any HTTP level parsing).
That’s why, when you want to use option forwardfor, you need to enable HTTP mode.
If I understand correctly then, the problem is that the forwardfor entry in the defaults section is applying to all the rules, so it would be better to remove it from there and include it only in the backend that require http?
Correct. You can also define an additional default section before you begin with the tcp sections and not define http specific features there.
This would then overwrite the previous default section.
Thank you very much lukastribus!!!
