OTLP-(GRPC / HTTP) Frontend / Backend configs
We need to pass OpenTelemetry signal data through HAProxy (v2.0.33 with L7 enabled, and SSL offloading) to the k8s hosted OTEL collector on one of our clusters.
We are looking for suggested configurations for frontend and backend to account for both otlp-grpc (4317) and otlp-http (4318).
Thank you in advance
haproxy -vv
HA-Proxy version 2.0.33-0ubuntu0.1 2023/10/31 - https://haproxy.org/
  TARGET  = linux-glibc
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-TeMZuT/haproxy-2.0.33=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
Feature list : -51DEGREES +ACCEPT4 -CLOSEFROM +CPU_AFFINITY +CRYPT_H -DEVICEATLAS +DL +EPOLL -EVPORTS +FUTEX +GETADDRINFO -KQUEUE +LIBCRYPT +LINUX_SPLICE +LINUX_TPROXY +LUA -MY_ACCEPT4 -MY_EPOLL -MY_SPLICE +NETFILTER +NS -OBSOLETE_LINKER +OPENSSL -PCRE +PCRE2 +PCRE2_JIT -PCRE_JIT +POLL +PRCTL -PRIVATE_CACHE -PTHREAD_PSHARED +REGPARM +RT -SLZ -STATIC_PCRE -STATIC_PCRE2 +SYSTEMD +TFO +THREAD +THREAD_DUMP +TPROXY -VSYSCALL -WURFL +ZLIB
Available services :
        prometheus-exporter
Whats NOT working
haproxy config
frontend otlp-rpc
  bind *:4317 ssl crt apps.mycluster.mydomain.com.pem alpn h2,http/1.1
  option http-use-htx
acl otlp_grpc dst_port 4317
use_backend otlp_grpc_servers if otlp_grpc
  server  worker1   10.1.1.4:4317 ssl verify none proto h2
  server  worker2   10.1.1.5:4317 ssl verify none proto h2
  server  worker3   10.1.1.6:4317 ssl verify none proto h2
  server  worker4   10.1.1.7:4317 ssl verify none proto h2
This results in sending 503 back to the client (an otel collector attempting to send log data).
