I’m running haproxy 2.8.3 with tomcat9 as a backend server.
How would I have to configure haproxy such that it serves the address:
HAPROXY TOMCAT9
https://cms.site.org/ ==> https://cms.site.org:8443/
HAPROXY TOMCAT9
You could do something like this:
frontend www
bind *:443 ssl crt /etc/haproxy/website.pem
default_backend tomcat9
backend tomcat9
server srv1 1.2.3.4:8443 ssl
Thanks. What does the ssl in the backend section do? Is it necessary?
Or in other words: I just added the ssl specifier and get an error on startup:
Jun 7 10:12:21 mail haproxy[13143]: [ALERT] (13143) : config : [/etc/haproxy/haproxy.cfg:85] : 'server cmssite/cms.myserver.org' : verify is enabled by default but no CA file specified. If you're running on a LAN where you're certain to trust the server's certificate, please set an explicit 'verify none' statement on the 'server' line, or use 'ssl-server-verify none' in the global section to disable server-side verifications by default.
Jun 7 10:12:21 mail haproxy[13143]: [ALERT] (13143) : config : Fatal errors found in configuration.
EDIT: I see, it checks the availability of a certificate on the backend beforehand, at configuration or start time other than later when real traffic would occur.
