Hi there,
I am trying to set up HAProxy in front of some node js apps but having trouble with performance. In the best case I get just under half the performance of a raw node server.
I have a simple hello world app -
const http = require(‘http’);
const server1 = http.createServer((req, res) => {
res.statusCode = 200;
res.setHeader(‘Content-Type’, ‘text/plain’);
res.end(‘Hello World 1’);
const server2 = http.createServer((req, res) => {
res.end(‘Hello World 2’);
server1.listen(3000, ‘0.0.0.0’, () => {});
server2.listen(3001, ‘0.0.0.0’, () => {});
When I do wrk -c100 -d10 http://localhost:3000 I am getting around 10k req/sec
I set up haproxy and have tried multiple different configs but I can not get even half the speed of raw server. Is that normal?
Here’s my latest config that gets around 4k req/sec -
maxconn 50000
log 127.0.0.1:514 local0 info
maxconn 50000
frontend http_front
bind *:5000
stats uri /haproxy?stats
default_backend http_back
backend http_back
server server_name1 0.0.0.0:3000 check
server server_name2 0.0.0.0:3001 check
What am I doing wrong or is that normal to have HAProxy cut the req/sec in more than half?
Thank you!
