I am setting up a new haproxy server and am getting unusually slow performance compared to a single server solution.
I use Haproxy18 in front of httpd2.2.
My conf:
chroot /var/opt/rh/rh-haproxy18/lib/haproxy
pidfile /var/run/rh-haproxy18-haproxy.pid
stats socket /var/opt/rh/rh-haproxy18/lib/haproxy/stats mode 666 level user
maxconn 2000
timeout client 10000
timeout server 10000
frontend prodAnciennehttps
bind *:443
default_backend prdhttps
backend prdhttps
server app1 192.168.1.215:443 maxconn 200
backend prdhttp
server app1 192.168.1.215:80 maxconn 200
listen stats # Define a listen section called “stats”
bind :9000 # Listen on localhost:9000
stats enable # Enable stats page
stats hide-version # Hide HAProxy version
stats realm Haproxy\ Statistics # Title text for popup window
stats uri /haproxy_stats # Stats URI
stats auth Username:Password # Authentication credentials
My load average is 140 sessions max.
Thanks a lot.
