I’m using my local Kubernetes env (v1.19.3) and trying to deploy Haproxy with the yaml file below:
But it can not create pods’ status is “crashloopbackoff”.
And when I check the logs of the pod, it says permission denied error like below;
[root@server]# kubectl logs haproxy-ingress-67f7c8b555-qhr4p
2021/01/13 10:52:05
_ _ _ ____
| | | | / \ | _ \ _ __ _____ ___ _
| |_| | / _ \ | |_) | '__/ _ \ \/ / | | |
| _ |/ ___ \| __/| | | (_) > <| |_| |
|_| |_/_/ \_\_| |_| \___/_/\_\\__, |
_ __ _ |___/ ___ ____
| |/ / _| |__ ___ _ __ _ __ ___| |_ ___ ___ |_ _/ ___|
| ' / | | | '_ \ / _ \ '__| '_ \ / _ \ __/ _ \/ __| | | |
| . \ |_| | |_) | __/ | | | | | __/ || __/\__ \ | | |___
|_|\_\__,_|_.__/ \___|_| |_| |_|\___|\__\___||___/ |___\____|
2021/01/13 10:52:05 HAProxy Ingress Controller v1.4.13 75fd943
2021/01/13 10:52:05 Build from: git@github.com:haproxytech/kubernetes-ingress.git
2021/01/13 10:52:05 Build date: 2021-01-07T10:41:15
2021/01/13 10:52:05 ConfigMap: haproxy-controller/haproxy
2021/01/13 10:52:05 Ingress class:
2021/01/13 10:52:05 Publish service:
2021/01/13 10:52:05 Default backend service: haproxy-controller/ingress-default-backend
2021/01/13 10:52:05 Default ssl certificate: haproxy-controller/
2021/01/13 10:52:05 Controller sync period: 5s
2021/01/13 10:52:05 PANIC controller.go:241 mkdir /etc/haproxy/certs: permission denied
I tried to create manually /etc/haproxy/certs directory but didn’t worked.
How can I solve this problem? Thanks!
