File sharing works fine through HAProxy, and I can see the printer shared through HAProxy.
But when I’m on a Win10 system and double click on the printer shared via HAProxy I get an “Operation could not be completed 0x00000709” error.
No error when going directly to the Win10 system sharing the printer.
I’m new to HAProxy and have never gotten printer sharing to work, so this might be a newbe error.
Tshark on the Ubuntu system running HAProxy shows a lot of SMB packets on port 445 as you would expect with the printer share visible to the Win10 client.
But then the connection starts to go to DCERPC protocol over some higher ports like 50213 then EPM protocol and finally a RST and the connection is closed.
My goal is to eventually get HAProxy to load balance two print servers, but I’m not able to get one print server working through HAProxy.
No firewall issues:
sudo firewall-cmd --list-all
sudo: firewall-cmd: command not found
sudo ufw status verbose
Status: inactive
cfg file looks valid.
sudo haproxy -c -f /etc/haproxy/haproxy.cfg
Configuration file is valid
It’s running.
sudo systemctl status haproxy.service -l --no-pager
Active: active (running) since Thu 2023-06-15
sudo journalctl -u haproxy.service --since today --no-pager
Jun 15 16:01:23 LM-U systemd[1]: Starting HAProxy Load Balancer…
Jun 15 16:01:23 LM-U haproxy[2071]: [NOTICE] (2071) : New worker #1 (2073) forked
Jun 15 16:01:23 LM-U systemd[1]: Started HAProxy Load Balancer.
cat /etc/haproxy/haproxy.cfg
frontend ft_tcp
bind *:88
bind *:135
bind *:137
bind *:138
bind *:139
bind *:445
default_backend bk_tcp
backend bk_tcp
stick-table type ip size 200k expire 60s
stick on src
default-server inter 1s
server lm-xws 10.0.0.5
Any suggestions would be greatly appreciated.
