Issue with config file
I am trying to implement below HAproxy load balancer:
haproxy -v
HAProxy version 2.4.22-0ubuntu0.22.04.2 2023/08/14 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.4.22.html
Running on: Linux 6.2.0-36-generic #37~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Mon Oct 9 15:34:04 UTC 2 x86_64
But facing following errors:
sudo haproxy -c -f /etc/haproxy/haproxy.cfg
[WARNING] (6071) : parsing [/etc/haproxy/haproxy.cfg:45] : backend ‘http_back’ : ‘option httplog’ directive is ignored in backends.
[WARNING] (6071) : parsing [/etc/haproxy/haproxy.cfg:56] : backend ‘http_fsmback’ : ‘option httplog’ directive is ignored in backends.
[NOTICE] (6071) : haproxy version is 2.4.22-0ubuntu0.22.04.2
[NOTICE] (6071) : path to executable is /usr/sbin/haproxy
[ALERT] (6071) : parsing [/etc/haproxy/haproxy.cfg:66] : unknown proxy mode ‘https’.
[WARNING] (6071) : parsing [/etc/haproxy/haproxy.cfg:68] : backend ‘https_back’ : ‘option tcplog’ directive is ignored in backends.
[ALERT] (6071) : parsing [/etc/haproxy/haproxy.cfg:78] : unknown proxy mode ‘https’.
[WARNING] (6071) : parsing [/etc/haproxy/haproxy.cfg:80] : backend ‘https_fsmback’ : ‘option tcplog’ directive is ignored in backends.
[ALERT] (6071) : Error(s) found in configuration file : /etc/haproxy/haproxy.cfg
[ALERT] (6071) : Fatal errors found in configuration.
Below is the config file:
Default SSL material locations
See: Mozilla SSL Configuration Generator
stats realm Haproxy Statistics
stats uri /Haproxy_stats
stats auth admin:admin
frontend http_front
default_backend http_back
backend http_back
server server101 10.10.24.101:80 check
server server102 10.10.24.102:80 check
frontend http_fsm
bind *:8080
default_backend http_fsmback
server server101 10.10.24.101:8080 check
server server102 10.10.24.102:8080 check
frontend https_front
bind *:443
default_backend https_back
backend https_back
mode https
server server101 10.10.24.101:443 check
server server102 10.10.24.102:443 check
frontend https_fsm
bind *:8080
default_backend https_fsmback
mode https
This is the first time i am using HAProxy, Can anyone assist please, where i am doing wrong?
Thanks in Advance
Zaheer Ahmad
you use the listening. I think it’s simpler and easier to read.
Bye
