Problems getting started - the most rudimentary config file throwing errors
Config File: (yes that’s all of it)
maxconn 10000
stats socket /var/run/haproxy.stat mode 600 level admin
log 127.0.0.1 local0
chroot /var/empty
frontend stats
bind *:10001
stats hide-version
stats refresh 10s
stats show-node
stats uri /stats
Error at startup
[NOTICE] (1055104) : haproxy version is 2.7.3
[NOTICE] (1055104) : path to executable is /usr/local/sbin/haproxy
[ALERT] (1055104) : config : Parsing [/etc/haproxy/haproxy.cfg:9]: frontend ‘stats’ has the same name as frontend ‘stats’ declared at /etc/haproxy/haproxy.cfg:9.
[ALERT] (1055104) : config : Error(s) found in configuration file : /etc/haproxy/haproxy.cfg
[ALERT] (1055104) : config : Fatal errors found in configuration.
