Problems with images
Hi , i’m new with haproxy…we have 2 backends that serve serveral web apps and in one app we generate a pdf file with a barcode image…in those backend i can generate the pdf and i can see the barcode image…but if i get the pdf over the haproxy in this pdf cant see the barcode image.
Develop department add the image by memory stream…
This is my backend config:
backend back_Secuenciadores30
option httpchk GET /Secuenciadores30
no option httpclose
http-check expect ! rstatus ^5
cookie SERVER_Secuenciadores30 insert indirect nocache
server VIDALCORE01 192.168.1.35:80 check cookie VC1
server VIDALCORE02 192.168.1.45:80 check cookie VC2
server VIDAL-ASP2 192.168.1.52:80 check cookie VIDAL-ASP2
Global config:
stats timeout 8600s
tune.bufsize 32768
#See: https://ssl-config.mozilla.org/#server=haproxy&server-version=2.0.3&config=intermediate
    ssl-default-server-options no-sslv3 no-tlsv10 no-tlsv11 no-tlsv12 no-tls-tickets
# reenvio directo con la IP de Origen del paquete
timeout client 30s
timeout server 30s
