Haproxy fails to display correctly website that locally displays fine
website: https://juimonos.com/
shows missing images, internally in admin doesnt list users .
haproxy ip 192.168.1.6
cert shows ok
but internally in my local area network , without haproxy , or https, the website loads everything fine as expected:
webserver ip:192.168.1.4
type: nginx virtual host called juimonos.com
port 443
Haproxy configuration:
    ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE>
timeout connect 3s
timeout client 5s
timeout server 5s
timeout http-request 5s
timeout http-request 10s # Preventing Slowloris like attacks
option http-buffer-request
frontend haprx01
bind 192.168.1.6:80
bind 192.168.1.6:443 ssl crt /etc/ssl/sw.prem crt /etc/ssl/juimonos.prem crt /etc/ssl/sym.prem crt /etc/ssl/larifanet.prem crt /etc/ssl/ticofds.prem
http-request deny if HTTP_1.0
http-request deny if { req.hdr(user-agent) -i -m sub curl phantomjs slimerjs }
http-request deny unless { req.hdr(user-agent) -m found }
http-request deny if { src -f /etc/haproxy/blacklist.acl }
acl whitelist src -f /etc/haproxy/whitelist.lst
ACL for “serviciosymas.com
acl ACL_sym hdr(host) -i serviciosymas.com www.serviciosymas.com
use_backend sym if ACL_sym
ACL for “juimonos.com
acl ACL_juimonos hdr(host) -i juimonos.com www.juimonos.com
use_backend juimonos if ACL_juimonos
nginx virtual host config: (ssl requested and installed as well here)
server {
root /wbs/carpool/www/public/;
index index.php index.html index.htm index.nginx-debian.html;
server_name juimonos.com www.juimonos.com;
    location / {
            try_files $uri $uri/ /index.php?q=$uri&$args;
    location ~ \.php$ {
       include snippets/fastcgi-php.conf;
       fastcgi_pass unix:/run/php/php7.4-fpm.sock;
listen [::]:443 ssl ipv6only=on; # managed by Certbot
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/juimonos.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/juimonos.com/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = www.juimonos.com) {
return 301 https://$host$request_uri;
} # managed by Certbot
if ($host = juimonos.com) {
    listen 80;
    listen [::]:80;
return 404; # managed by Certbot
cloudflare setting:
Please help, I want to get this website fully loading https just like http works normally internally.
What I am doing wrong?
haproxy version 2.4
i checked haproxy logs located at /var/log/
hundreds of errors were shown telling
basically the connection was dropped before even was sent to backend
i went by discard method and found this rule that i got from some haproxy block was the culprit
http-request deny if { sc_http_req_rate(0) gt 10 } this one is problematic
now what is that rule for? its supposed to deny DDOS attacks but is malformed?
from the docs
let’s say that you wanted to block any client making more than 10 requests per second. The http_req_rate(10s) counter that you added will report the number of requests over 10 seconds. So, to cap requests at 10 per second, set the limit to 100.
maybe the 10 requests per seconds are to low. if you have a site with lot of images, css, javascript then the 10 requests could easily be reached…
