Hello! After setup haproxy, png picture not displayed on the site! On the application catalog have the file ‘test_code_location.png’. My colleague some time ago added to configs settings for show this picture, but picture still didn’t printed on the page site! may be they are setting was wrong! Instead of a picture on the site I see a picture icon! When I go to this web page without haproxy, the png picture successfully loading !
How I can try fix it? Thanks
haproxy config:
option httplog clf
log-format '"json_msg":{"client_ip":"%ci","client_port":"%cp","frontend_name":"%f","timestamp":"%Ts","frontend_name_transport":"%ft","backend_name":"%b","node_name":"%s","time":{"tq":%Tq,"tw":%Tw,"tc":%Tc,"tr":%Tr,"tt":%Tt},"res.status":"%ST","req.method":"%HM","request":"%HU","bytes_read":"%B","captured_request_cookie":"%CC","captured_response_cookie":"%CS","termination_state_with_cookie_status":"%tsc","actconn":"%ac","feconn":"%fc","beconn":"%bc","srv_conn":"%sc","retries":"%rc","srv_queue":"%sq","backend_queue":"%bq","req.host":"%[capture.req.hdr(0)]","referer":"%[capture.req.hdr(1)]","remote_addr":"%[capture.req.hdr(2)]","req.id":"%[capture.req.hdr(3)]","response_headers":"%hs"}'
timeout connect 280000
timeout client 280000
timeout server 280000
option forwardfor header X-Real-IP
frontend check.front
bind 127.0.0.1:8004 alpn h2,http/1.1
#,spdy/3.1
capture request header Host len 100
capture request header Referer len 100
capture request header X-Request-ID len 100
http-request add-header X-Request-ID %ID
http-response set-header Strict-Transport-Security max-age=15768000;\ includeSubdomains;\ preload
http-response set-header X-Frame-Options DENY
acl url_css path_beg /test/css/
use_backend test.back if url_css
acl url_img path_beg /test/images/
use_backend test.back if url_img
acl url_test path_beg /test/
use_backend test.back if url_test
acl url_img1 path /test_code_location.png
use_backend check.back if url_img1
frontend checkvisa.front
bind 127.0.0.1:8009 alpn h2,http/1.1
#,spdy/3.1
use_backend test.back if { path /test_code_location.png }
default_backend checkvisa.back
frontend reports.front
bind 127.0.0.1:8010 alpn h2,http/1.1
#,spdy/3.1
default_backend reports.back
backend check.back
# proxy host/ to host/test (xxxx.test.ua to xxxx.test.ua/test)
reqirep ^([^/])/(.) \1/test/checkcontract/?code=\2
http-request replace-uri ^([^/]*)/(.*) \1/test/checkcontract/?code=\2
# proxy cookie XSESSIONID Path=/evo.rc/checkcontract to Path=/
# http-response replace-header Set-Cookie XSESSIONID=(.*);Path=/evo.rc/checkcontract(.*) XSESSIONID=\1;Path=/\2
http-response replace-header Set-Cookie JSESSIONID=(.);Path=/test/checkcontract(.) JSESSIONID=\1;Path=/\2
option httpchk HEAD /test/checkcontract/ HTTP/1.0
option httpclose
retry-on conn-failure empty-response 0rtt-rejected
option log-health-checks
server test-1 test-1:8080 check inter 8000 rise 2 fall 3 weight 100
server test-2 test-2:8080 check inter 8000 rise 2 fall 3 weight 100
server test-3 test-3:8080 check inter 8000 rise 2 fall 3 weight 100
