my config, please help
Example configuration for a possible web application. See the
full configuration options online.
http://haproxy.1wt.eu/download/1.8/doc/configuration.txt
Global settings
# to have these messages end up in /var/opt/rh/rh-haproxy18/log/haproxy.log you will
# need to:
# /etc/sysconfig/syslog
# 2) configure local2 events to go to the /var/opt/rh/rh-haproxy18/log/haproxy.log
# local2.* /var/opt/rh/rh-haproxy18/log/haproxy.log
log 127.0.0.1 local2
chroot /var/opt/rh/rh-haproxy18/lib/haproxy
pidfile /var/run/rh-haproxy18-haproxy.pid
maxconn 4000
# turn on stats unix socket
stats socket /var/opt/rh/rh-haproxy18/lib/haproxy/stats
ssl-default-server-ciphers PROFILE=SYSTEM
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
frontend main
acl url_static path_beg -i /static /images /javascript /stylesheets
acl url_static path_end -i .jpg .gif .png .css .js
acl acl_myApp path_sub ebid
use_backend static if url_static
default_backend app
static backend for serving up images, stylesheets and such
backend static
server static 127.0.0.1:4331 check
round robin balancing between the various backends
backend app
reqrep ^GET\ /(.*) GET\ /ebid/\1
server app1 app1:80 check
server app2 app2:80 check
