Simple backend configuration always returns 404
I’m trying to put 10.43.231.254:80 behind haproxy2.2 but for some reason, haproxy always returns a 404 not found when I attempt to site
I tried copying the example from Configuration | Configuration Section Basics | Frontend | HAProxy Enterprise 2.2r1 and applying to my setup, but i’m not having much luck
proof that the host that is running haproxy is able to reach 10.43.231.254:80
/etc/haproxy$ curl 10.43.231.254:80 | head
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0<!DOCTYPE html>
<html lang="en-US">
<head>
        <meta charset="UTF-8" />
        <meta name="viewport" content="width=device-width, initial-scale=1" />
<meta name='robots' content='max-image-preview:large' />
<title>User&#039;s Blog! &#8211; Just another WordPress site</title>
<link rel='dns-prefetch' href='//s.w.org' />
<link rel="alternate" type="application/rss+xml" title="User&#039;s Blog! &raquo; Feed" href="http://10.43.231.254/feed/" />
<link rel="alternate" type="application/rss+xml" title="User&#039;s Blog! &raquo; Comments Feed" href="http://10.43.231.254/comments/feed/" />
100 30871    0 30871    0     0   502k      0 --:--:-- --:--:-- --:--:--  502k
I confirm that the service is able to start:
:/etc/haproxy$ sudo /usr/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -S /run/haproxy-master.sock
Proxy http started.
Proxy web_servers started.
[NOTICE] 287/191035 (33578) : New worker #1 (33580) forked
And here is my configuration file
/etc/haproxy$ cat haproxy.cfg
        log stdout format raw local0
        log /dev/log    local0
        log /dev/log    local1 notice
        log /dev/log    local0 debug
        log     global
        mode    http
        option  httplog
        option  dontlognull
        timeout client  50000
        timeout server  50000
frontend http
        default_backend web_servers
backend web_servers
        server server1 10.43.231.254:80
And here is the 404 error:
/etc/haproxy$ curl localhost
404 page not found
Haproxy never emits 404 Not found.
Either something else is listening port on 80 or your backend service returns that.
Try checking the response headers with curl -vv localhost
Thanks, after switching haproxy to another port, I am getting the expected behaviour
