Trying to use haproxy to balance requests to a few urls in aws cloud from inside our business network. I keep getting 404 not found for the host IP where haproxy is running if i remove the acl’s, if leave the acl’s i get 502 bad gateway
here is the config.
log 127.0.0.1 local2
maxconn 500
#ssl-server-verify none
timeout connect 30000
timeout client 60000
timeout server 60000
default-server init-addr none
retries 999
resolvers dnsserver
nameserver public-0 1.1.1.1:53
hold valid 100ms
resolve_retries 3
frontend https
bind *:443 npn spdy/2 alpn h2,http/1.1
acl oauth path_end -i /oauth
acl devices path_end -i /devices
use_backend back_oauth if oauth
use_backend back_devices if devices
backend back_oauth
#option ssl-hello-chk
server host1 https://test.io:443/oauth/token?grant_type=client_credentials resolvers dnsserver check ssl
server host1 https://test.io:443/devices resolvers dnsserver check
bind *:8080
just to verify a few things
im using haproxy 1.7
DNS seems to be working fine.
I can use ACL’s with tcp mode right ?
does everything look ok above ?
Eventually I have to use a certificate but for now im just trying to hit with postman and ignore cert.
thanks for any help
No, you cannot use ACL in TCP mode. You also cannot announce spdy or H2 support, if neither haproxy or your backend supports it. You also need to decide whether you want to decrypt SSL at haproxy or not.
Invalid, you need to specify IP:port or hostname:port, not an URI.
same here.
If you can explain what you are trying to do, I can help. But the configuration is completely wrong on a number of levels, so I’m unable to guess what you are trying to achieve exactly.
thanks.
I have to use URLs i dont have IP’s the redirection is to cloud where there is no IP only url.
Here is what i am trying to do.
i have a dozen or so requests that have to come from 1 server at a site…to cloud. This host where haproxy is running is in the middle.
So a request will come in, hit this haproxy on port 443 and based on which url it is…
ie /oauth
or /devices
or i have a bunch of other ones.
It should transparently move that request to the url in cloud.
It must be on port 443
as for the cert - there needs to be a cert handshake so haproxy should not terminate the cert, it should just pass the request through transparently. So the cloud app will look at cert and it should accept it from the requesting server, not from haproxy. hopefully i explained this so its understandable.
fyi - i checked the stat page and it looks as if dns resolution is happening ok as It shown UP for the backend
What you are trying to do is technically impossible.
HTTPS means it’s encrypted with TLS. You cannot read the URI from those requests, unless you decrypt it first.
im trying to do a ssl passthrough, so it just passes the cert along with out terminating it, so far i got it passing the request through but the issue now is that the server with the cert is seeing the host as different so in the haproxy logs im seeing this
localhost haproxy[20410]: 3.202.247.200:62482 [05/Jun/2019:14:56:02.681] https https/ -1/-1/0 0 SC 0/0/0/0/0 0/0
and in postman i get back a 404 with an error from the server (not haproxy server)
404 Not Found: Requested route (‘IP of haproxy here:443’) does not exist.
frontend https
bind *:443
#use_backend back_oauth if { req_ssl_sni -i test.io }
default_backend back_oauth
backend back_oauth
server host1 https:/test.io:443/oauth/token?grant_type=client_credentials resolvers dnsserver check
so its sending the request to the server which is good, but the server is seeing the request header as the IP of the server with haproxy on it.
any idea what im doing wrong ?
First of all you need to fix that server statement. I already told you you cannot specify a URL there.
You probably want:
server host1 test.io:443 resolvers dnsserver check
Your browser does not send the Host header your backend expects (and the neither is the SNI value correct at this point). You need to point the DNS records to your haproxy box and use the correct hostname in the browser, than your backend will find it.
