Hello!
Our company provides Proxy-like solution with Load balancing for our customer, one of our new customer wants to have the packets send to him from us with the Proxy Protocol v2 for HTTPS traffic, normally we ask customer to upload a certificate to our Proxy device but this customer insists on not uploading it, so we don’t have a certificate on our device.
I red online that the Proxy Protocol should still work, but when I try and access the webpage I get this error:
When testing with CURL from a Linux machine:
The proxy protocol seems to be messing up the TLS handshake, but I am not sure why, have you encountered this before? Think you can help me out with the script?
This is the script I am using:
when CLIENT_ACCEPTED {
The binary header format starts with a constant 12 bytes block containing the protocol signature
set sig \x0d\x0a\x0d\x0a\x00\x0d\x0a\x51\x55\x49\x54\x0a
The next byte (the 13th one) is the protocol version and command.
The highest four bits contains the version. As of this specification, it must always be sent as \x2 and the receiver must only accept this value.
The lowest four bits represents the command :
- \x1 : PROXY : the connection was established on behalf of another node, and reflects the original connection endpoints. The receiver must then use the information provided in the protocol block to get original the address.
set ver_cmd \x21
The 14th byte contains the transport protocol and address family. The highest 4 bits contain the address family, the lowest 4 bits contain the protocol.
if {[IP::version] == 4} { # IPv4
set address_family 1
} elseif {[IP::version] == 6} { # IPv6
set address_family 2
if {[IP::protocol] == 6} { # TCP
set transport_protocol 1
} elseif {[IP::protocol] == 17} { # UDP
set transport_protocol 2
set fam [binary format cu [expr [expr $address_family << 4] + $transport_protocol]]Starting from the 17th byte, addresses are presented in network byte order.
The address order is always the same :
- source layer 3 address in network byte order
- destination layer 3 address in network byte order
- source layer 4 address if any, in network byte order (port)
- destination layer 4 address if any, in network byte order (port)
set src_addr [binary format c4 [split [IP::client_addr] .]]
set dst_addr [binary format c4 [split [IP::local_addr] .]]
set addr [IP::client_addr]
set ip6_list [split $addr :]
while {[llength $ip6_list] < 8} {
set ip6_list [linsert $ip6_list [lsearch -exact $ip6_list “”] “”]
for {set i 0} {$i < [llength $ip6_list]} {incr i} {
set ip6_list [lreplace $ip6_list $i $i [format %04s [lindex $ip6_list $i]]]
set src_addr [binary format H32 [join $ip6_list “”]]set addr [IP::local_addr]
set dst_addr [binary format H32 [join $ip6_list “”]]
set src_port [binary format Su [TCP::client_port]]
set dst_port [binary format Su [TCP::local_port]]
set src_port [binary format Su [UDP::client_port]]
set dst_port [binary format Su [UDP::local_port]]
set addr $src_addr$dst_addr$src_port$dst_portThe 15th and 16th bytes is the address length in bytes in network endian order.
set len [binary format Su [string length $addr]]
Complete proxy protocol header
set proxy_protocol_v2 $sig$ver_cmd$fam$len$addr
TCP::collect
when CLIENT_DATA {
TCP::payload replace 0 0 $proxy_protocol_v2
TCP::release
-----END
Example of PCAP taken on our Load balancer (Which is the same device doing the proxy):
For security reasons I hid the IPs but see below:
- Red is my server which is trying to reach the customer’s server.
- Blue is our Load balancer.
- Violet is our customer’s Server.
Some explanation - Our device is using Force proxy delayed binding, which means its completing TCP hand with my server, only then he negotiates TCP handshake with customer’s server, this is the first TCP handshake on the PCAP.
Thanks a lot if you even read this message, would really appreciate any help you can offer me!
