I have some PHP scripts that run a ton and connect up to a RabbitMQ backend, send some data to it and then disconnect.
It turns out that the connecting and disconnecting part a lot causes an increase in CPU load on the RabbitMQ server.
Can HAProxy be used at all to help? I am thinking if it could hold open some persistent connections to the RabbitMQ server that HAProxy might be more efficient at the connect/disconnect bit?
