Hey there,
I’m running haproxy 2.0.14-1~bpo10+1 2020/04/16.
I’m encountering the error, that in one request all ACL’s work just fine. And if I or someone else reloads the site or connects for the first time, the ACL’s wont work anymore.
This is random. Sometimes it works sometimes it doesn’t.
I’m running not running any SSL/TLS Certificate on the haproxy.
I’m not sure what can cause this.
Here’s my config:
log /dev/log local0 info
log /dev/log local1 info
# ca-base /etc/ssl/certs
# crt-base /etc/ssl/private
ssl-default-bind-options ssl-min-ver TLSv1.2
frontend server_http
#acl's
##sahnee public stuff
#sahnee.de
acl is_sahneedehttp hdr(host) -i sahnee.de
acl is_sahneedehttp1 hdr(host) -i www.sahnee.de
#sahnee.dev
acl is_autodiscover hdr(host) -m beg -i autodiscover.sahnee.dev
acl is_autodiscover2 hdr(host) -i autodiscover.sahnee.dev
acl is_autodiscover3 hdr_beg(host) -i autodiscover.sahnee.dev
acl is_autodiscover4 hdr(host) -m sub -i Autodiscover.xml
acl is_autodiscover5 hdr(host) -m dom -i autodiscover.sahnee.dev
acl is_sahneedevhttp hdr(host) -i sahnee.dev
acl is_sahneedevhttp1 hdr(host) -i www.sahnee.dev
##sahnee internal stuff
##other stuff
#custom backends
use_backend autodiscover_http if is_autodiscover
use_backend autodiscover_http if is_autodiscover2
use_backend autodiscover_http if is_autodiscover3
use_backend autodiscover_http if is_autodiscover4 or is_autodiscover5
use_backend sahneeserverhttp if is_sahneedevhttp or is_sahneedevhttp1 or is_sahneedehttp or is_sahneedehttp1
#Default Backend
default_backend hosting_defaulthttp
frontend server_https
bind *:443
#acl's
##sahnee stuff
acl is_sahneedev req_ssl_sni -i sahnee.dev
acl is_sahneedev1 req_ssl_sni -i www.sahnee.dev
acl is_sahneede req_ssl_sni -i sahnee.de
acl is_sahneede1 req_ssl_sni -i www.sahnee.de
acl is_autodiscover req.ssl_sni -m beg -i autodiscover.sahnee.dev
acl is_autodiscover2 req.ssl_sni -i autodiscover.sahnee.dev
acl is_autodiscover3 req.ssl_sni -m sub -i Autodiscover.xml
acl is_vault req.ssl_sni -i vault.sahnee.internal
##other stuff
#other backends
use_backend vault_https if is_vault
use_backend sahneeserverhttps if is_sahneedev or is_sahneedev1 or is_sahneede or is_sahneede1
use_backend autodiscover_https if is_autodiscover or is_autodiscover2 or is_autodiscover3
#Default Backend
default_backend hosting_defaulthttps
http-response set-header Strict-Transport-Security max-age=16000000;\ includeSubDomains;\ preload;
server websrv02 10.12.10.118
server websrv02https 10.12.10.118
server websrv01 10.12.10.10
#internal servers
server exchange_http 10.11.10.106
server exchange_https 10.11.10.106
backend vault_https
server vault 10.11.10.105:8200
so far I think I’ve tried a whole lot…
Thats why some things look strange and the autodiscover acls are mixed up.
Thanks ahead for any help
