Hi guys,
I’m using haproxy 2.5 and have some basic rate limiting configured like this (the actual configuration contains more rules for different urls):
backend test
acl rate_limit_by_ip_exceeds_limit src,table_http_req_rate(rate_limit_by_ip) gt 100
http-request deny deny_status 429 if rate_limit_by_ip_exceeds_limit
http-request track-sc0 src table rate_limit_by_ip
backend rate_limit_by_ip
stick-table type ipv6 size 1m expire 24h store http_req_rate(5m)
Is there any way to include a “retry-after” header in case the rate limit is exceeded? And especially, how to calculate the value of that header? I used Caddy before, and it provided this header out of the box (GitHub - mholt/caddy-ratelimit: HTTP rate limiting module for Caddy 2).
Thanks for any help!
Corin
