I need help to solve my issue.
What I want to achieve is
http://abc.contoso.com → https://abc.contoso.com
(Force redirection HTTP to HTTPS)
My problem is that the URI needed for Azure OAuth 2.0 authorization endpoint doesn’t match.
The accepted URI as destination when returning authentication responses (tokens) after successfully authenticating users must be: https://abc.contoso.com/signin-oidc
But HAProxy sends the HTTP form as below:
Sign in to your account profile&response_mode=form_post
What should I do to have the HTTPS form instead of HTTP for OAuth?
My config is
frontend public_front_end bind *:80 mode http option forwardfor redirect scheme https code 301 if !{ ssl_fc } frontend public_secured_front_end bind *:443 ssl crt /etc/haproxy/certsuse_backend abc-api if { hdr(host) -i abc.contoso.com }
backend abc-api
server webserver01 192.168.0.1:4569 check
