I’d like to redirect to https unless it’s already https or if the Host header is present in a map file and imagine that this would work (this is in the frontend):
redirect scheme https code 302 unless { ssl_fc || hdr(Host),map(no_tls.map) -m found }
…but it doesn’t. Can anyone tell me if it’s possible and if so how to do it?
I’ve also tried the following, but that doesn’t work either:
redirect scheme https code 302 unless { ssl_fc || hdr_dom(Host) foo.bar.org }
I’m using v1.8.14.
Thanks in advance,
Björn
