Redirection with https
Helps please.
I’m trying to configure redirection.
I would like to do that :
if client enters https://example.com it will be redirect to https:://www.site.com
My configuration is :
redirect prefix https://www.site.cm if { hdr(host) -i example.com }
But when the user enters https://example.com it’s redirect to the root folder.
How can i correct this issue ?
Thanks in advance !!
Share your complete configuration please?
My configuration
maxconn 5000
frontend www-http
option httpclose
redirect prefix https://www.site.cm if { hdr(host) -i www.example.com }
frontend www-https
bind *:443 ssl crt /key.pem
option httpclose
default_backend defaultBackendServer
redirect scheme http code 301 if !{ ssl_fc }
balance source
server SRV-WEB-1 192.168.2.13:80 check
server SRV-WEB-2 192.168.2.14:80 check
backend testBackend
balance source
acl no_redir url_beg   /test/test/
reqirep ^([^\ :]*)\ /(.*)     \1\ /test/test/\2 if !no_redir
bind 192.168.2.16:1992
maxconn 2
clitimeout 100s
srvtimeout 100s
contimeout 100s
timeout queue 100s
stats hide-version
stats refresh 30s
stats show-node
stats auth admin:password
stats uri /haproxy?stats
I don’t see anything wrong with this configuration.
What do you see from a curl output?
curl -vv http://example.com
curl -vv http://www.example.com
