I am new in Haproxy Load Balancing and i am doing okay in redirecting traffic on two different URLs. But unable to mask URL for client end because all I want is to redirect traffic from test.uv.edu.pk to test1.uv.edu.pk and test2.uv.edu.pk without changing URL at client end so that client could not see the backend URLs.
Some of my configurations are shared below:
frontend test
bind 192.168.128.10:80
acl is_test.uv.edu.pk hdr(host) -i test.uv.edu.pk
use_backend test_backend_servers if is_test.uv.edu.pk
default_backend test_backend_servers
reqrep ^([^\ ]*)\ (.*) \1\ \2
server test1 192.168.128.11:80 maxconn 5000 check
server test2 192.168.128.12:80 maxconn 5000 check
Regards,
Khuram
