Dear All,
the acl below works and forwards the request to acl profile_uri
however the following requests issued by the first page of the profile app goes to other backends because the app does not know about load balancer paths.
IS there a way to stick the user to the same backend?
how can i cope with this
regards
Emre
option httpclose
frontend http_front
acl profile_uri path_beg -i /profile
use_backend manfrontend if profile_uri
use_backend http_rear unless profile_uri
default_backend http_rear
backend manfrontend
server webC 10.154.22.33:4007
backend http_rear
server wbs1 10.154.22.33:3000
backend http_rear
server wbs1.com 10.154.22.33:3000 check
backend manfrontend
server webC 10.154.22.33:4007 check
