I have setup a haproxy config file as follow, and try to verify redispatch function, however, when i set the balance algorithm as source, i get 3 retry(from stats web page) and finally get a 503 error, the request does not redspatch to s2 when I kill s1, is anything wrong with my cfg, any helps are appricicated. I am using haproxy 1.6.10
# logging to rsyslog facility local3 [err warning info debug]
log 127.0.0.1 local1 notice
log 127.0.0.1 local3 warning
log 127.0.0.1
stats bind-process 4
stats socket /tmp/haproxy.sock mode 0600 level admin
maxconn 51200
ulimit-n 102434
pidfile /var/wd/ehaproxy/haproxy.pid
nbproc 4
#cpu-map TODO
spread-checks 5
mode http # [tcp|http|health]
backlog 10000
#retries 0
maxconn 15000
errorfile 500 /var/wd/ehaproxy/conf/500.http
errorfile 502 /var/wd/ehaproxy/conf/502.http
errorfile 503 /var/wd/ehaproxy/conf/503.http
errorfile 504 /var/wd/ehaproxy/conf/504.http
no option httpclose
option log-separate-errors
option abortonclose
option forwardfor # X-Forwarded-For: remote client ip
timeout client 10m
timeout server 10m
timeout connect 1s
#timeout tunnel 10m
timeout http-keep-alive 6m # ?
timeout queue 1m
timeout check 5s
#timeout http-request 5s
default-server minconn 50 maxconn 5000 inter 80s rise 2 fall 3
listen 0.0.0.0:10910
bind 0.0.0.0:10910
bind-process 1
stats uri /stats
listen 0.0.0.0:10911
bind 0.0.0.0:10911
bind-process 2
stats uri /stats
listen 0.0.0.0:10912
bind 0.0.0.0:10912
bind-process 3
stats uri /stats
listen 0.0.0.0:10913
bind 0.0.0.0:10913
bind-process 4
stats uri /stats
listen sub
bind 0.0.0.0:19192
balance source
server s1 192.168.149.150:22222 weight 4
server s2 192.168.149.150:9192 weight 4
