Hi All,
Some 503 returns still occur, even if Redispatch is configured.
HAproxy and Hashicorp Consul on the same server.
Environment:
Consul v1.10.0 - Revision 27de64da7
rogerio@cloud:/lblog$ sudo haproxy -vv HAProxy version 2.4.2-1~bpo10+1 2021/07/07 - https://haproxy.org/ Status: long-term supported branch - will stop receiving fixes around Q2 2026. Known bugs: http://www.haproxy.org/bugs/bugs-2.4.2.html Running on: Linux 4.19.0-16-cloud-amd64 #1 SMP Debian 4.19.181-1 (2021-03-19) x86_64 Build options : TARGET = linux-glibc CPU = generic CC = cc CFLAGS = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-2.4.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference OPTIONS = USE_PCRE2=1 USE_PCRE2_JIT=1 USE_OPENSSL=1 USE_LUA=1 USE_SLZ=1 USE_SYSTEMD=1 USE_PROMEX=1 DEBUG = Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -CLOSEFROM -ZLIB +SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS -OT -QUIC +PROMEX -MEMORY_PROFILING Default settings : bufsize = 16384, maxrewrite = 1024, maxpollevents = 200 Built with multi-threading support (MAX_THREADS=64, default=2). Built with OpenSSL version : OpenSSL 1.1.1d 10 Sep 2019 Running on OpenSSL version : OpenSSL 1.1.1d 10 Sep 2019 OpenSSL library supports TLS extensions : yes OpenSSL library supports SNI : yes OpenSSL library supports : TLSv1.0 TLSv1.1 TLSv1.2 TLSv1.3 Built with Lua version : Lua 5.3.3 Built with the Prometheus exporter as a service Built with network namespace support. Built with libslz for stateless compression. Compression algorithms supported : identity("identity"), deflate("deflate"), raw-deflate("deflate"), gzip("gzip") Built with transparent proxy support using: IP_TRANSPARENT IPV6_TRANSPARENT IP_FREEBIND Built with PCRE2 version : 10.32 2018-09-10 PCRE2 library supports JIT : yes Encrypted password support via crypt(3): yes Built with gcc compiler version 8.3.0 Available polling systems : epoll : pref=300, test result OK poll : pref=200, test result OK select : pref=150, test result OK Total: 3 (3 usable), will use epoll. Available multiplexer protocols : (protocols marked as <default> cannot be specified using 'proto' keyword) h2 : mode=HTTP side=FE|BE mux=H2 flags=HTX|CLEAN_ABRT|HOL_RISK|NO_UPG fcgi : mode=HTTP side=BE mux=FCGI flags=HTX|HOL_RISK|NO_UPG <default> : mode=HTTP side=FE|BE mux=H1 flags=HTX h1 : mode=HTTP side=FE|BE mux=H1 flags=HTX|NO_UPG <default> : mode=TCP side=FE|BE mux=PASS flags= none : mode=TCP side=FE|BE mux=PASS flags=NO_UPG Available services : prometheus-exporter Available filters : [SPOE] spoe [CACHE] cache [FCGI] fcgi-app [COMP] compression [TRACE] trace
Settings:
maxconn 30000
timeout client 6m
timeout server 6m
frontend cloud
bind :443 ssl crt /etc/ssl/private/cloud.com.br.pem alpn h2,http/1.1
bind :80
http-response set-header Strict-Transport-Security "max-age=31536000;"
http-response del-header Server
http-response del-header x-powered-by
http-response del-header x-aspnet-version
http-response del-header x-aspnetmvc-version
http-request capture req.hdr(X-Forwarded-For) len 64
acl VHOST_principal req.hdr(Host) -i -m dom cloud.com.br
use_backend mvc if VHOST_principal
backend mvc
option httpchk
http-check send meth GET uri / ver HTTP/1.1 hdr Host cloud.com.br
option redispatch 1
retry-on 503 conn-failure empty-response
retries 5
server-template mvc 51 _mvc._tcp.service.consul check fall 3 rise 2 resolvers proddns init-addr none
resolvers proddns
nameserver dns1 127.0.0.1:8600 # Hashicorp Consul
accepted_payload_size 8192
LOG:
Jul 30 09:39:04 cloud haproxy[12403]: ***.**.223.130:15250 [30/Jul/2021:09:39:04.847] cloud~ mvc/mvc45 0/2/1/0/3 503 493 - - ---- 9502/9502/144/0/+5 0/0 {******:3cb0:510:5d10} "GET /Home/Bloquear?__cnv=aKXd9&tenant=org000290 HTTP/1.1"
Jul 30 09:39:04 cloud haproxy[12403]: ***.**.24.206:47048 [30/Jul/2021:09:39:04.851] cloud~ mvc/mvc45 0/2/0/1/3 503 493 - - ---- 9502/9502/144/0/+5 0/0 {****.250} "GET /Home/ObterQuantidade?__cnv=myYip&tenant=org000194 HTTP/1.1"
Jul 30 09:39:04 cloud haproxy[12403]: ***.**.25.159:28712 [30/Jul/2021:09:39:04.854] cloud~ mvc/mvc45 0/2/0/0/2 503 493 - - ---- 9502/9502/145/0/+5 0/0 {****.191} "POST /Documento/ObterModelos?__cnv=hkOE8&idEmpresa=6&tenant=org000035 HTTP/1.1"
Jul 30 09:39:04 cloud haproxy[12403]: ***.**.26.194:19872 [30/Jul/2021:09:39:04.855] cloud~ mvc/mvc3 0/1/1/0/2 503 493 - - ---- 9502/9502/144/0/+5 0/0 {****.245} "POST /Integracao/ObterMercadorias?__cnv=mB2Zs&idEmpresa=1&tenant=org000211 HTTP/1.1"
Jul 30 09:39:04 cloud haproxy[12403]: ***.**.24.202:15432 [30/Jul/2021:09:39:04.865] cloud mvc/mvc3 0/2/0/0/2 503 493 - - ---- 9502/9502/144/0/+5 0/0 {*****.158.0} "GET / HTTP/1.1"
Jul 30 09:39:06 cloud haproxy[12403]: ***.**.24.196:12198 [30/Jul/2021:09:39:06.260] cloud~ mvc/mvc3 0/0/0/0/0 503 493 - - ---- 9502/9502/163/0/0 0/0 {****.255} "POST /NotaFiscal/Inserir?idRequisicao=9048&origemEmissao=NotaFiscalDeRequisicao&idFinanceiroConta=3&idEmpresa=3&idTipoItem=1&idNaturezaOperacao=3&valor=27&caixaRapido=True&__cnv=ru2Hd HTTP/1.1"
Jul 30 09:39:10 cloud haproxy[12403]: ***.**.24.254:20100 [30/Jul/2021:09:39:10.685] cloud~ mvc/mvc11 0/0/0/1/1 503 493 - - ---- 9508/9508/182/1/0 0/0 {****.189} "POST /NotaFiscal/Inserir?origemEmissao=7&idRequisicao=48340&idempresa=3&origemSPA=true&__cnv=qmPaU HTTP/1.1"
Jul 30 09:39:11 cloud haproxy[12403]: ***.**.25.159:53872 [30/Jul/2021:09:39:11.201] cloud~ mvc/mvc11 0/0/0/1/1 503 493 - - ---- 9516/9516/199/1/0 0/0 {****.29} "POST /DocumentoEntrada/Inserir?IdEmpresa=18&__cnv=jShsL HTTP/1.1"
Jul 30 09:39:11 cloud haproxy[12403]: ***.**.24.202:37318 [30/Jul/2021:09:39:11.599] cloud~ mvc/mvc11 0/0/0/0/0 503 493 - - ---- 9505/9505/211/0/0 0/0 {****.53} "POST /NotaFiscal/Inserir?idRequisicao=251481&origemEmissao=NotaFiscalDeRequisicao&idFinanceiroConta=117&idEmpresa=24&idTipoItem=1&valor=31.5&caixaRapido=True&__cnv=hgAfR HTTP/1.1"
Other LOGS
Consul LOG
Jul 30 08:31:56 cloud consul[899]: 2021-07-30T08:31:56.569-0300 [INFO] agent.server.serf.lan: serf: EventMemberJoin: ig-web-pro2-l1f9 10.100.100.96
Jul 30 08:31:56 cloud consul[899]: 2021-07-30T08:31:56.571-0300 [INFO] agent.server: member joined, marking health alive: member=ig-web-pro2-l1f9
HAProxy LOG
Jul 30 08:32:50 cloud haproxy[12400]: [WARNING] (12403) : mvc/mvc24 changed its IP from (none) to 10.100.100.96 by proddns/dns1.
Jul 30 08:32:50 cloud haproxy[12403]: mvc/mvc24 changed its FQDN from (null) to ig-web-pro2-l1f9.node.dc-gcp.consul by 'SRV record'
Jul 30 08:32:50 cloud haproxy[12403]: mvc/mvc24 changed its IP from (none) to 10.100.100.96 by proddns/dns1.
Jul 30 08:32:50 cloud haproxy[12403]: Server mvc/mvc24 ('ig-web-pro2-l1f9.node.dc-gcp.consul') is UP/READY (resolves again).
Jul 30 08:32:50 cloud haproxy[12403]: Server mvc/mvc24 administratively READY thanks to valid DNS answer.
Jul 30 08:32:50 cloud haproxy[12400]: [WARNING] (12403) : Server mvc/mvc24 ('ig-web-pro2-l1f9.node.dc-gcp.consul') is UP/READY (resolves again).
Jul 30 08:32:50 cloud haproxy[12400]: [WARNING] (12403) : Server mvc/mvc24 administratively READY thanks to valid DNS answer.
Jul 30 08:32:52 cloud haproxy[12403]: Server mvc/mvc24 is DOWN, reason: Layer7 timeout, check duration: 2000ms. 21 active and 0 backup servers left. 14 sessions active, 0 requeued, 0 remaining in queue.
Jul 30 08:32:52 cloud haproxy[12400]: [WARNING] (12403) : Server mvc/mvc24 is DOWN, reason: Layer7 timeout, check duration: 2000ms. 21 active and 0 backup servers left. 14 sessions active, 0 requeued, 0 remaining in queue.
Jul 30 08:32:53 cloud haproxy[12403]: ***.***.24.16:60494 [30/Jul/2021:08:32:50.096] cloud~ mvc/mvc24 0/0/1/2907/2908 200 385 - - ---- 10038/10038/233/13/0 0/0 {***.***.238.162} "GET /api/reports/clients/426667f63cd/instances/8d34bbc9b08/documents/eaf1914c75d11d1d886bcb/info HTTP/1.1"
Jul 30 08:32:58 cloud haproxy[12400]: [WARNING] (12403) : Server mvc/mvc24 is UP, reason: Layer7 check passed, code: 302, check duration: 3ms. 23 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jul 30 08:32:58 cloud haproxy[12403]: Server mvc/mvc24 is UP, reason: Layer7 check passed, code: 302, check duration: 3ms. 23 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jul 30 08:43:24 cloud haproxy[12403]: ***.***.24.254:47246 [30/Jul/2021:08:43:22.766] cloud~ mvc/mvc24 0/0/0/1290/1290 200 88834 - - ---- 9771/9771/153/5/0 0/0 {***.**.***.111} "POST /VeiculoEstoque/Obter/428?idRotina=57&leiaute=False&tipoFiltro=2&titulo=Estoque&__cnv=Ehh74&idEmpresa=2&tenant=org000251 HTTP/1.1"
Jul 30 08:43:25 cloud haproxy[12403]: ***.***.26.194:10698 [30/Jul/2021:08:43:25.205] cloud~ mvc/mvc24 0/0/0/1/1 503 493 - - ---- 9769/9769/195/2/0 0/0 {***.87.***.155} "POST /NotaFiscal/Inserir?idOSNotaFiscal=325843&origemEmissao=NotaFiscalDeOrdemDeServico&idFinanceiroConta=51&idEmpresa=13&idTipoItem=2&idNaturezaOperacao=1111&valor=254.82&caixaRapido=True&__cnv=8c6np HTTP/1.1"
Jul 30 08:43:25 cloud haproxy[12403]: ***.***.224.162:36718 [30/Jul/2021:08:43:25.759] cloud~ mvc/mvc24 0/0/0/20/20 503 493 - - ---- 9766/9766/213/1/0 0/0 {**:**:7a:**:562:***:5b84:f3a1} "POST /NotaFiscal/Inserir?idRequisicao=19920&origemEmissao=NotaFiscalDeRequisicao&idFinanceiroConta=21&idEmpresa=4&idTipoItem=1&idNaturezaOperacao=395&valor=63&caixaRapido=True&__cnv=XGuF4 HTTP/1.1"
Jul 30 08:43:30 cloud haproxy[12400]: [WARNING] (12403) : Server mvc/mvc24 is DOWN, reason: Layer7 wrong status, code: 503, info: "Service Unavailable", check duration: 0ms. 25 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
Jul 30 08:43:30 cloud haproxy[12403]: Server mvc/mvc24 is DOWN, reason: Layer7 wrong status, code: 503, info: "Service Unavailable", check duration: 0ms. 25 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
Jul 30 08:43:34 cloud haproxy[12400]: [WARNING] (12403) : Server mvc/mvc24 was DOWN and now enters maintenance (entry removed from SRV record).
Jul 30 08:43:34 cloud haproxy[12403]: Server mvc/mvc24 was DOWN and now enters maintenance (entry removed from SRV record).
Consul LOG
Jul 30 08:43:44 cloud consul[899]: 2021-07-30T08:43:44.784-0300 [INFO] agent.server.serf.lan: serf: EventMemberLeave: ig-web-pro2-l1f9 10.100.100.96
Jul 30 08:43:44 cloud consul[899]: 2021-07-30T08:43:44.784-0300 [INFO] agent.server: deregistering member: member=ig-web-pro2-l1f9 reason=left
