Hi
Using Tenable.SC i’ve got reported issue with plugin ID 12224 and I need to remove from headers information about responding server from load balancing.
How can I do it?
Hi
How can I do it?
In your frontend, add
http-response del-header
For instance, to remove the server header
http-response del-header Server
or
http-response del-header ^Server:.*
I typically include both for safety’s sake.
