I am trying to remove a cookie value by using the following:
http-request replace-header Cookie (;?\ ?sessionid=[^;];?\ ?)(.|\r\n) \2
If I have read the docs correctly this will find the ‘sessionid’ cookie value in the Cookie header and replace it with whatever comes after it, whether it is a string or a ‘\r\n’.
This appears to work, for the most part, but there are times that it also removes the values before it.
- what am I doing wrong???
- is there another way to do this??
Scott
