We’ve just upgraded from HAP 1.7 to 2.0.8 and a small percentages of our requests have started failing. After a TCP Dump, we noticed that the Request URL was:
GET https://redacted.host:443/ HTTP1/1\r\n
Host: redacted.host
These requests were returning a 400 Bad Request, but on 1.7 they worked just fine. So I broke out telnet and tried it manually.
FYI I had to remove the // from the URL’s in the RequestURI to pass the inspection of the post, it thought I was trying to share URL’s.
HAProxy 2.0.8 with 443 in Request URI
Connected to 192.168.0.1.
Escape character is '^]'.
GET https: redacted.host:443/ HTTP/1.1
Host: redacted.host
HTTP/1.1 400 Bad request
content-length: 90
cache-control: no-cache
content-type: text/html
connection: close
HAP 2.0.8 Without :443 in RequestURI
GET https: redacted.host/ HTTP/1.1
Host: redacted.host
HTTP/1.1 302 Found
Cache-Control: no-cache
Content-length: 0
HAproxy 1.7 Host (Both work, not going to bother posting both results)
Connected to 192.168.0.2
Host: redacted.host
HTTP/1.1 302 Found
Content-length: 0
The configurations are basically the same, but this one type of request is failing. Does anyone know a potential change between 1.7 and 2.0 that could cause this? Setting change? Anything?
