Route traffic by destination port
I would like to know if it’s possible to route the traffic by destination port to the same server and port ?
For example :
frontend tcp_balancing
bind    *:9000
bind    *:9001
use_backend tcp_9000   if dst-port int(9000)
use_backend tcp_9001   if dst-port int(9001)
backend tcp_9000
    server myserver check
backend tcp_9001
This should do the job:
use_backend tcp_9000   if { dst_port 9000 }
use_backend tcp_9001   if { dst_port 9001 }
thanks a lot
