Hello community,
i am a nooby with haproxy but until jet i can work with it.
I try to route requests with ftp. or sftp over port 5022 to one webserver.
So i configure:
frontend sftp_frontend
bind *:5022
default_backend httpserver
#ftp routing
acl sftp_in_uri path_beg sftp. ftp.
use_backend sftp_back if sftp_in_uri
backend sftp_back
server web01 192.168.2.50:5022 check
So i think all requests over port 5022 will be checked. If i enable that. It refused all requests to the webserver and i cant access my websites (Error Connection refused).
For my typo3 configuration it works;
frontend https_frontend
bind *:443
option httpclose
#layer7_for_typo3_ssl
acl url_typo3 path_beg /typo3
use_backend typo3_back_ssl if url_typo3
server webserver01-ssl 192.168.122:443 check
server webserver11-ssl 192.168.123:443 check
Have someone an idea why the routing is stopped if i enable the ftp and sftp configuration an maybe why it doesnt work?
All requests with (http:// / https://) ftp.xxxx.com or sftp.xxxxx.com should be routed.
cheers HiTTi
