i want to forward more domains with the same port to different lxc containers on the port 8008 (tcp).
If I don’t do the acl-check the config is working. But I need to check the url.
Here is my config:
log /dev/log	local0
log /dev/log	local1 notice
log	global
mode	tcp
option	tcplog
option tcp-smart-connect
option	dontlognull
option  dontlognull
    timeout client  50000
    timeout server  50000
frontend stratum1_frontend
bind *:8008
acl host_stratum1 hdr_dom(host) -m beg test1.
use_backend stratum1_backend if host_stratum1
#default_backend stratum1_backend
server stratum1 test1.test.de:8008 check
