Sanity check on my haproxy.conf file as a reverse proxy for Hugo
I’m currently learning some new stuff like building a simple website using Hugo and encrypting it with a Let’s Encrypt certificate. Unfortunately Hugo doesn’t have native support for SSL so I quickly found solutions for this by using HAProxy as a reverse proxy.
I’ve since watched a bunch of videos, read various parts of the documentation and blog posts and some tutorials. It’s a very basic website and I’ve come up with the following configuration for my HAProxy.
Please note I’m running this inside a TrueNAS (FreeBSD) Jail using iocage. I had to change the logging configuration part to get that to work but I managed to find some useful resources for that.
I would like to have a sanity check on my configuration file. How does this look for a basic configuration as a reverse proxy with SSL termination? Should I change anything, or add additional must-have configuration options I might have missed?
I want to use this as a basis for hosting more sites in the future using ACLs.
  • HAProxy version: HA-Proxy version 2.2.8
  • Hugo version: Hugo Static Site Generator v0.80.0
  • OpenSSL version: OpenSSL 1.1.1h
        maxconn 1024
        user root
        group wheel
        log /var/run/log local0 debug
        ssl-default-bind-options ssl-min-ver TLSv1.2
        option httplog clf
        option logasap
        timeout client 30s
        timeout server 30s
frontend hugo_http
        http-request add-header X-Forwarded-Proto: http
        default_backend hugo
frontend hugo_https
        bind *:443 ssl crt /usr/local/etc/letsencrypt/live/<domain>/haproxy.pem
        http-request add-header X-Forwarded-Proto: https
backend hugo
        server s1 127.0.0.1:1313
Thank you for your replies!
I would suggest you don’t use option http-server-close, because the default keep-alive-mode will perform better.
There is no point really in adding the X-Forwarded-Proto: http header and specifying the default backend in the http frontend, when you redirect everything to HTTPS anyway.
I would also handle:
in the default section, and remove it everywhere else. You are only duplicating configuration, complicating the configuration unnecessarily.
Since I created this topic I’ve been watching and reading even more. I’ve also found the Mozilla SSL Configuration Generator and used it for my HAProxy.
I removed both the forward headers already, should I keep the https one in?
I also put everything in one frontend section. I used the SSL Labs tester to see how my configuration holds up and I got an A-rating. This is how my configuration file looks now:
        maxconn 1024
        user root
        group wheel
        ssl-default-bind-options prefer-client-ciphers no-sslv3 no-tlsv10 no-tlsv11 no-tls-tickets
        option httplog clf
        option logasap
        timeout client 30s
        timeout server 30s
frontend hugo
        http-response set-header Strict-Transport-Security "max-age=15778800; includeSubDomains; preload;"
backend hugo
        server hugo 127.0.0.1:1313
Whether you keep X-Forwarded-Proto: https in there or not depends on whether hugo uses it or not.
