I have a haproxy infront of Percona MySQL cluster. HAproxy is TCP proxying connection towards Percona with send-proxy-v2.
In the log lines, I’m seeing around 40% of SD connection termination states which haproxy logs as an error. If I disable SSL login, then the connections terminates OK and there is no problem. I have search the web for similar issues but couldn’t find a solution. The closest was Intermittent "SD" termination state - #3 by uliromahn, but we are not using nolinger option.
Error:
Aug 9 16:13:49 mysql-lb1 haproxy[346659]: 2001:yyyy:xxxx:44::4:51724 [09/Aug/2024:16:13:49.260] mysql-db1X mysql-db1X/mysql-db1a 1/0/149 39165 SD 44/42/41/41/0 0/0
HAproxy, client and DB servers are all in the same L2 network and I tried disabling firewall on the servers just to be sure firewall is not messing things up. No win:)
tcpdump of a request that returns SD state (cja host is the client):
When I disable SSL, the last RST package does not happen and seems like the only difference in the tcpdump.
Haproxy config:
maxconn 2048
pidfile /var/run/haproxy.pid
maxconn 8000
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout check 10s
listen mysql-pdc2-db1X
bind xxxx:3306
bind yyy:3306
option httpchk
option clitcpka
option srvtcpka
timeout queue 1m
timeout client 8h
timeout server 8h
server mysql-pdc2-db1a x.y.v.z:3306 check send-proxy-v2 port 9200 inter 2s rise 3 fall 2
server mysql-pdc2-db1b x.y.v.z1:3306 check send-proxy-v2 backup port 9200 inter 2s rise 3 fall 2
server mysql-pdc2-db1c x.y.v.z:3306 check send-proxy-v2 backup port 9200 inter 2s rise 3 fall 2
The application (client) works OK as I always get the whole response from the MySQL server back, but haproxy is incrementing error counters which is not ideal:)
We are using haproxy 2.4.22 (bundled with RHEL 9).
Any idea / help would be appreciated, because I have no idea where to search for solution.
Thanks.
