I need to select a backend based on jdbc string connection.
jdbc:postgresql://localhost:443/mydb
For example, if the jdbc connection contains postgresql the request must be redirected to the corresponding backend. I tried to capture content with req.payload but I got nothing. I think this is because one of these thee options:
- The jdbc driver encrypts the credentials by default and not way to see it.
- I am working in the wrong tcp layer.
- I am trying to capture
contentwhen there is not content in this type of request.
The script is this:
log localhost local1 notice
maxconn 2000
frontend tcp-in
bind *:443
tcp-request inspect-delay 1s
log-format %[capture.req.hdr(0)]
tcp-request content capture req.payload(0,0) len 100
tcp-request content capture req.len len 100
tcp-request content accept if WAIT_END
acl postgresql req.payload(0,0) -m sub postgresql
use_backend postgresql if postgresql
acl virtuoso req.payload(0,0) -m sub virtuoso
use_backend virtuoso if virtuoso
backend postgresql
option pgsql-check user postgres
server postgresql postgresql:5432 check
backend virtuoso
server virtuoso virtuoso:1111 check
Any idea how to overcome this?
Thanks in advance
