For a POC, I am testing a haproxy config to allow access to different Postgresql instances on the same server, based on a hostname.
Serveur RHEL8 / HAProxy 1.8 / Postgresql 14
IE :
iaspX.domain.tld → postgresql1:54321
iaspY.domain.tld → postgresql2:54322
etc.
Here is the tested config.
# Global settings
log /dev/log local0 debug
pidfile /var/run/haproxy.pid
maxconn 4000
# turn on stats unix socket
timeout client 1m
timeout server 1m
timeout check 10s
maxconn 3000
# statistics
bind *:7000
stats uri /
stats refresh 20s
stats realm PSQL Haproxy\ Statistics # Title text for popup window
stats show-node
stats show-legends
stats show-desc PSQL load balancer stats (master)
frontend pgsql_in
bind *:5432
tcp-request inspect-delay 10s
use_backend bk_iasp1 if { hdr(host) -m beg pgsql-lat-iasp1. }
use_backend bk_iasp2 if { hdr(host) -m beg pgsql-lat-iasp2. }
#default_backend iasp1
# round robin balancing between the various backends
backend bk_iasp1
option tcp-check
tcp-check connect
server psql1 127.0.0.1:54321 check
backend bk_iasp2
option tcp-check
tcp-check connect
server psql2 127.0.0.1:54322 check
It seems that the use_backend directives, depending on the host, do not work. If I add the default_backend directive, on one of the two postgres instances, the connection works.
Thanks for your help
