I am just changing the haproxy.cfg file and starting it (in centos7) sudo systemctl start haproxy.
Below is the full haproxy configuration
Example configuration for a possible web application. See the
full configuration options online.
Global settings
# need to:
# /etc/sysconfig/syslog
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 4000
# turn on stats unix socket
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
frontend main *:80
acl url_x path_beg /x/
acl url_y path_beg /y/
use_backend x-backend if url_x
use_backend y-backend if url_y
static backend for serving up images, stylesheets and such
backend static
server static 127.0.0.1:4331 check
round robin balancing between the various backends
backend x-backend
reqrep ^([^\ ])\ /x(/.) \1\ \2
server x_master0 xxx.xx.xx.163:80 check cookie x_master0
server x_master1 xxx.xx.xx.171:80 check cookie x_master1
server x_master2 xxx.xx.xx.181:80 check cookie x_master2
backend y-backend
reqrep ^([^\ ])\ /y(/.) \1\ \2
server y_server0 xxx.xx.xx.67:8080 check cookie y_server0
