Redirect based on hostname
Hello there,
I’m having trouble setting up HAProxy for my application.
I need to redirect to a path based on the hostname.
For example the server where HAProxy is listening respond to two hostnames: “fooBAR.app” and “FOObar.app”.
Now when I send a request to “http://foo.app/” I would like it to be sent to 1.2.3.4:8080/fooBAR-application/, same for “http://FOO.app/” that should go to 1.2.3.4:8080/FOObar-application/.
This is my cfg file:
# globals
    log 127.0.0.1 local0
# common defaults
    mode                    http
    retries                 3
    timeout http-request    10s
    timeout queue           1m
    timeout connect         10s
    timeout client          1m
    timeout server          1m
    timeout http-keep-alive 10s
    timeout check           10s
    maxconn                 3000
# main frontend
frontend main_fe
    acl fooBAR hdr(host) -i fooBAR.app
    acl FOObar hdr(host) -i FOObar.app
    http-request set-path /fooBAR-application/ if fooBAR
    http-request set-path /FOObar-application/ if	FOObar
    use_backend fooBAR_be if fooBAR
    use_backend FOObar_be if FOObar
    default_backend fooBAR_be
# main backend
backend fooBAR_be
    balance     roundrobin
    server fooBAR1 172.21.80.13:8080 check
backend FOObar_be
    balance     roundrobin
    server FOObar1 172.21.80.13:8080 check
Many thanks.
