Hi.
I have a send-proxy aware app running on an appserver which only allows tcp port access on 3336 from an haproxy box (I have tested this from my remote machine and unable to see the open port and the ip is listed below you are also free to try it). On the haproxy side I have firewall rules blocking a specific ip, yet I see periodically 0.0.0.0 show up on the app server log (there is nothing from the app server that would be hitting that port)
Ubuntu 16.04 LTS
HA-Proxy version 1.8.12-1ppa1~xenial 2018/06/27
See logs:
2018-10-22 09:33:15 [0.0.0.0] , x16r, no data
2018-10-22 09:32:46 [90.143.45.55] , x16r, no data
I am using mode tcp as follows:
log /dev/lo local1 notice
maxconn 32768
nbproc 1
nbthread 4
# stats socket /run/haproxy/admin.sock mode 660 level admin
timeout client 99m
timeout connect 60s
timeout server 99m
frontend rvn
bind *:3636
default_backend stratum_rvn
backend stratum_rvn
server rvn1 198.27.74.99:3636 send-proxy-v2
server rvn2 198.27.74.99:3635 send-proxy-v2
I have also enabled the “usual” anti-spoofing rules using iptables:
-N spoofing
-I spoofing -j LOG --log-prefix “Spoofed source IP”
-I spoofing -j DROP
-A INPUT -s 255.0.0.0/8 -j spoofing
-A INPUT -s 0.0.0.8/8 -j spoofing
which have not helped.
Appreciate any insight how I can deal with this.
