Hi!
I switched from nginx to HAProxy for load balancing because HAProxy does support health-checks (yeah!).
Current config:
frontend https-local
bind :443
use_backend local-default-http2
default_backend bknd-down
option ssl-hello-chk
option httpchk HEAD /index.html HTTP/2.0\r\nHost:\ sub.domain.de\r\nUser-Agent:\ HAPROXY-CHECK
server nginx_http2 sub.domain.de:5009 check check-ssl inter 1000 verify none
backend bknd-down
# server errorfile?
HAProxy checks every second if the sub.domain.de:5009 server is reachable (I replaced the domain with sub.domain.de). When the server is down (or more the app isn’t running so /index.html can’t be requests) it just see a ‘ERR_CONNECTION_CLOSED’ error in chrome.
I thought I could simply add a default_backend to the frontend which is used when all the other servers available (it’s only one in my example) are down. But that’s not working.
How can I achieve that? When the local-default-http2 backend has no server available show an errorfile.
Thank you very much!
