Hello community!
I’m posting here as I came across an issue that I’m not able to resolve and I’ve been searching around for a while now. I had a working config using SSL termination with 1 single frontend for 80 and 443 and 2 backends for 2 different websites. After enabling SSL passthrough the second website (site2) stopped working with the given error and I am not sure if it’s due to the tcp mode with an httpcheck in it at the backend level.
HAproxy version: haproxy/bionic-updates,bionic-security,now 1.8.8-1ubuntu0.10
HAproxy config
maxconn 2000
#option forwardfor
timeout tunnel 3600s
timeout http-keep-alive 1s
timeout http-request 15s
timeout queue 30s
timeout tarpit 60s
frontend http_in
frontend https_in
bind *:443
acl tls req.ssl_hello_type 1
tcp-request content accept if tls
stats uri /haproxy?stats
acl is_websocket path_beg -i /api
acl host_calabrio req.ssl_sni -i site1.domain.com
acl host_ece req.ssl_sni -i site2.domain.com
use_backend api_back_calabrio if is_websocket
use_backend https_back_calabrio if host_calabrio
use_backend https_back_ece if host_ece
#Calabrio backend https
option ssl-hello-chk
default-server inter 3000 fall 2
server CLBPC1-LAB2-1 172.20.104.52:443 check cookie s1
server CLBPC2-LAB2-1 172.21.104.52:443 check backup cookie s2
#Calabrio backend API
server CLBPC1-LAB2-1 172.20.104.52:8888 check
server CLBPC2-LAB2-1 172.21.104.52:8888 check backup
#Cisco ECE backend https
option httpchk HEAD /default
http-check expect ! rstatus ^5
server ECE1-LAB2-1 172.20.206.45:443 check ssl verify none cookie s1
server ECE2-LAB2-1 172.21.206.45:443 check ssl backup verify none cookie s2
The backend that is not working is “backend https_back_ece” and the log entry with the issue is the following:
Apr 30 12:50:29 CLB1-LAB2-1 haproxy[1477]: 192.168.151.36:55267 [30/Apr/2020:12:50:28.995] https_in https_back_ece/ECE1-LAB2-1 1/0/47 505 – 11/11/0/0/0 0/0
The first backend is working without issues.
Any clue on why it’s giving back the SSL protocol error?
Thank you!
Tofaz
